Any FOH Engineers in the House? QC mixing question
When mixing a QC, where you do you normally set Gain and Comp on the board? Been using about 25% for each. Wanted to know if anyone else has thoughts.
Any kind of ā€˜standard’ gain setting makes no sense at all. All desks are different.
Proper method for setting gain for ANY source:
  1. Solo the channel (this should generally show you the input level on the main meters)
  2. Have the person in question make the loudest noise they are intending to make on that source.
  3. Adjust channel gain to have that channel peaking at around 0dB*
*for analogue desks, or for ā€˜analogue-style’ meters on digital desks.
Essentially you want to have the loudest possible signal you can, without it ever being in danger of clipping. IF you later find you have the channel faders pulled way down because the source is too loud, it’s better to pull the gain down and keep the faders closer to unity.
Compression depends on many factors, but namely - style of music, tone of guitar, dynamics of guitar, room sound… If it’s a one knob comression control, just adjust it to taste.
I agree with the post above (though you don’t even need to solo the track if you have either a PFL switch/meter or a dedicated meter per track).
I usually start with Comp off and gain at the minimum possible setting (and pad in) and bring up gain so as to ā€œfill the channelā€ properly (ie hit yellow to light orange on level meters) to get the best possible signal to noise ratio.
So as a rule of thumb if your loudest presets output at around -18dB FS (per the Output meter on the QC) you should be safe.
Compression only happens if I feel the dynamic range’s too big and I need to better control it (so low signals aren’t as low and loud signals aren’t as loud). If your levels are properly staged on your presets and they don’t go from super soft to crazy loud, little to no compression is necessary (I usually don’t ever use compression on electric guitars, distorted sounds are pretty compressed as is anyway).
Makes perfect sense but our mixer doesn’t have a needle. Just a light that blinks when it’s clipping.
What about a starting point? That’s why I mentioned percentages rather than absolute positions.
Thanks for the reply. I’ll turn comp off and see how it sounds. Usually the faders for my guitar are around -10 to -15 dB.
Yup, I’ve levelled all my patches so they output the same level (except for lead).
Why do you engage the pad?
So as to start from the lowest possible amplification factor (since it’s basically what the gain knob is for, and the pad switch allows you to toggle between different amplification ranges). Preamp gain is here to amplify signal as needed, as a rule of thumb I strive to mess with incoming signal as little as possible (might be a byproduct of doing jazz for a while now).
And having the faders around -10dB usually is fine, as they usually are logarithmic and that’s about the spot where the taper gets flatter (hence moves are more precise).
In that case, turn it up til the light flashes, then back off a bit until it stops. Sounds like it’s an analogue desk, so shouldn’t be too bad if you get the occasional clip. They tend to design them so that the clipping LED goes off before it actually clips too.
Both my setup at home (plain Jane behringer mixer → power amp) and at church on Sundays (PreSonus something or other) the gain for the channels (I run 2 channels and pan one completely left, and one completely right) is set at 0dB.
I run the rotary ā€œmaster volumeā€ knob on the QC at 100%. I just feel like it sounds truer and fuller to my ear.
This gives my FOH the whole range of the fader(s) to play with. They love it.
FOH engineer and guitarist here. The posts above are spot on. There’s no ā€œoneā€ gain setting you can pre-set unless you’re working with the same player with the same gear into the same board regularly, and then it’s always adjusted to suit whatever level I’m getting on the day.
I always start with the compressor wide open and only compress if my ears tell me it needs it. That’s always in the context of how the guitar is sitting in the whole mix, never in solo and never in line check. Most of the time, the guitarists I’m mixing are compressing on their board, and even if they’re not specifically ā€œcompressingā€, the amp and the drives are compressing the signal anyway. So I’m rarely compressing at FOH, and if I am it’s usually just super fast compression that’s shaving 2-3dB of the odd transient here and there.
Very helpful, thank you.
