Amp Block Shift in Same Row?
Hey there- tried to upload a video of this issue but cannot.
Running into something where simply shifting the two amp blocks and EQ block one position to the right (in the same rows) is creating a massively different output/sound.
does anyone have experience with this?
in my quick search it usually has to do with changing which row it’s in, amp level settings changing (they remained constant), or output/send settings changing. None of that occurred here.
Why am I getting such a different sound with just this simple move? (Just trying to create space for another block).
It has everything to do with where you are placing the amps around that split and merge.
ah! I missed that. And you sent me down a proper rabbit trail for better understanding split and merge.
Thank you!
Cheers and Godspeed.
