Hi, there are a ton of requests for more MIDI control already. These two have a lot of votes. We should not be adding new requests for MIDI at this point.
OK, this really needs to be fixed. The idea of having midi controls assigned ONLY to the switches is ridiculous and frustrating. It keeps this beautiful sounding device completely locked away from expansion. In reality it turns the “Most powerful floor modeler on the planet” into “Just another limited (yet expensive) 8-device/settings” processor. IF you can’t give us on/off (i.e. 0=off, 1 or higher = on) control for each device then assign on/off to the grid numbers and give us the ability to ma…
There are loads of midi commands that can be triggered on preset loading but only one per scene. A few more per scene would really help. Quite often you might want to change preset on an outboard pedal and turn one or two on or off so I think at least 4 commands would really help. If it could trigger midi notes as well that would be even better but I’d settle for 4 PC’s / CC’s
Thanks!!
