Not really sure what’s going here, and I’ve tried every trouble shooting scenario possible. Running a Volt 276 into a iMac / Logic Pro.
It happens on clean channels across all of the DSP plugins. You can hear the drum part from Superior Drummer on my recorded guitar track. It’s almost like a mic bleed. So when I want to have an isolated guitar part with no drums I’m getting the drum part that used to be underneath. Even when I mute the drums and even delete the drum track I still get the drum section bleeding through onto my guitar part. And even when I just use a click track to keep time I get that as well. This is crazy.
Use headphones-
This DOES NOT happen when I turn off the plugin or when I disable the amp inside the plugin. It’s in the amp section of the plugin, and turning up the gain makes it worse. And no clipping on any of my inputs and outputs.
Also, this does not happen with Guitar Rig, ToneX, STL Tones, Friedman IRX.
Any Ideas? Thanks in advance.
