Hello,
my Concern is to Add Footswitches for Bank Up/ Down…
only Midi or is a simple 2 way footswitch possible?
i need more than 4 sounds =/
Hello,
do you tell me why?^^ I am not oN reverb and from Germany^^
I’ve been using a Morningstar MC8 which does everything one can do with the NC. It can do a lot of other things, too. Solid build. They also make smaller devices.
Hi, I’m using a midicaptain mini 6 for paintaudio and it’s very usefull. You need a textedit to program it but it’s not so hard to understand.
Hi!
Did you figure it out if it’s possible to add a regular footswitch to activate/deactivate fx blocks? I would prefer a footswitch than a midi controller. I know you can do it with an expression pedal, but is it possible with a regular 2 vias footswitch?
Thanks.
