I would like to use other fx pedal with my love nano cortex, but want to listen to you how to order, how to use with other member in your pedal board please.
I use a Switcher (Fender or the Quartermaster) to have the Nano as the heart of my pedalboard. It works perfectly even though my home rig has 11 other FX pedals on it. I also have the Airstep Nano on my home board mainly because it’s very useful and I can locate the Nano pedal anywhere because I don’t need the foot switch access to it. I suggest you use a dedicated power supply rather than a general pedalboard PU. Hope this helps.
i have the 1987 pedal in front of nano cortex with a cab sim of a vox ac30 c2. i.e., a cab sim completely clean. also, no noise gate, no compressor, no delay, no chorus. only reverb.
looks like this:
in some point i had a EHX East River Drive, then a Strymon Sunset, but with a Peavey cab sim and now this 1987 AllPedals with a Vox AC 30
Well, I use Nano Cortex TRS Outs with TRS → XLR converters so I can use them with FOH instead of using a line isolator.
Because of that, every time based effect comes before the Nano. Nano is last in the chain.
I would however prefer to use an FX loop if possible.
It is already a requested feature to use R-Out → Capture In as FX loop so until that is available, I use everything before the NC. So, I only use clean amps or if I use dirty amps, I use Nano’s FX.
I think that is a pretty cool option even the way it is now.
