Problem:
Right now there are a ton of captures on the cloud which have little to no information. Which can be really annyoing. Some steps have already been taken to better this issue, like the addition of gain structure and filtering by instrument. But the problem still remains.
Solution / Feature request:
When sharing a capture publicly(!), it should be mandatory(!) to fill in all predetermined spaces of details about it. The only exception would be if a picture is uploaded.
In addition to what is already in place (like author, name, preferred instrument, etc.) I would like to see added:
The majority of users will behave the same way they always have–putting in the bare amount of effort just to get their captures loaded on their Quad Cortex or up on the cloud.
Instead of typing “Mesa Boogie Mark VII Head” in the amp device field they will type “…”
Instead of methodically listing out their settings, they will put “Bass 1 Mid 1 Treble 1 Gain 1”, etc., whatever is the fastest way to just get through the prompt and upload
If a photo is allowed in the place of filling out the settings fields, then users will upload literally anything just to get the capture up
Adding more fields for users to fill out is fine. The users who care will use them to everyone’s benefit.
But I definitely don’t think it should be mandatory, as aggravating as that can be for the people searching for captures. It won’t solve the problem of user-generated content; it will only result in more roadblocks for everyone.
You wouldn’t have to put in any more effort then right now if you upload for yourself. Just when sharing publicly.
And even if what you described would happen, which I don’t think would be the norm, it would help. Because if someone won’t even spend like 20 seconds to add some much needed information and just types in random stuff, you can at least see that.
Say I upload a capture of my setup and name it VMT 50 M15. It makes perfect sense for me. But you most likely wouldn’t know what it even is. Is it an amp? Amp with cab? Pedal?
At the end of the day NDSP has the last word on what is being shared publicly and how it is being shared. And I think everyone would win if we would all use the same system. As long as there is no official system, everyone will use their own.
At what point will the company start to clean the system of junk ? It’s a minefield of junk and really I can’t be bothered with most of it , imo they need to implement a system which would benefit everyone otherwise you’d be better off just buying the ones you like from a different company.
No need to make it mandatory, but maybe there could be a show/hide button for captures that don’t have the details filled out.
I was looking for a V2 capture of one of my pedals since I can only create V1 captures on Linux. There were plenty of captures of the pedal, but none had any info on the settings used.
I already knew the settings I wanted, so I thought it would be pretty easy to find a capture with those settings. Instead, it would have been a whole project to go through all the captures and try to find one with the settings in mind. No thanks.
I made a feature request some time ago addressing exactly this and other issues with the cloud captures management. Specifically comparing to the Tone3000 quite strict (and honestly better working) system.
I’ve seen other requests and posts regarding related topics. It would be great if we could manage to make a single Feature Request collectively, somehow. The way it is now there’s a few votes here and there and I can’t see this gaining much traction.
