Hi! I don’t understand why it’s not possible to add more than two reverbs of the same type in a Quad Cortex preset. With other effects, you can do it, but with the reverb no. You can help me?
I don’t think there is a limit per se to how many reverbs you can place. You are probably hitting the CPU limit for the rows.
The CPU is split into 50% for rows 1+2 and 50% for 3+4.
So if you have all blocks in rows 1 and 2, you could split that up and keep the amps and pre effects in the top half and place the reverbs in rows 3/4.
You absolutely can have more than two reverbs haha
