Add a volume setting to Wah block. When I switch to wah I find the volume of the effect too loud. A simple addition of a level control in the block would eliminate the need to add another gain block to the grid.
Hey,
You can add (I’m sure you gor available slots) a GAIN after your wah, assign it to the same switch to turn on/off and control the volume from there.
Hope that helps
Every block NEEDS to have a master volume and mix
I agree on the mix knob. And there is a feature request for that as well. But why a master/volume knob?
Because it eliminates the need for an additional gain block if you are in need of an adjustment in volume - like the OP is.
yep - exactly DRSTV!
