Ability to select blocks and export as a capture to use on nano
Rather than using the capture process to run a signal through and create a capture, it would be great if you could select a chain of devices on the QC and then create a capture, or one that can be consolidated into a capture block and used on the Nano Cortex.
Especially with the new plug-in updates, it would be great if we could easily take the core of that preset and use it on the Nano Cortex.
