Build "Nano Lab" Desktop Application for Capture Creation
There is a significant desire within the NC community have have more flexibility, access, and creativity in the utilization of Neural captures. While the NC does allow capturing a full physical chain, not everyone has access to all the pedals and amps of their dreams. While there are many pedal and amp captures in Cortrex Cloud, there are far fewer “full rig” captures available, and even within those, the odds of finding just the right combination of devices and settings YOU want would be like winning the lottery 3 times in a row.
What would be ideal is unlocking access to the full breadth of pedal, amp, pre/power-amp, cab captures in Cortex Cloud, and then allowing the user to mix and match, to assemble their ideal processing chain and settings and then capture that setup as a full rig.
While some requests already exist (Add another neural capture slot option to the chain?) requesting for more flexibility in slots on the NC itself, they do pose the challenge of significantly altering the on-device UI and control schemes. But the desire expressed there is clear - unlock the full power of Cortex Cloud for the NC.
I propose a different track, create a new desktop app (or enhance Cortex Control) called Nano Lab.
Nano Lab, once a user was logged into the Neural account, would let you search and filter Cortex Cloud to easily find captures of all kinds. You could then import 2-3 captures (OD, amp, cab or OD preamp, poweramp or OD, amp, cab, etc.) into a QC grid-like UI. A dedicated IR/Cab block loader should be the 3rd/4th slot respectively always and would have a toggle to include it in the capture or not (when just used to audition the chain).
Users would fill up the Nano Lab slots, click on each block, adjust parameters as desired, and once everything was sounding great, click “Send to Nano” and a capture of the current chain would be taken and pushed to the Nano Cortex as a single 'full rig" capture. Given that the NC can act as an interface, it should be viable to do the signal routing to plug into it and audition the capture chains before initiating the “re-capture” process and sending it to the device.
Sample Nano Lab Default UI
Users would click the “+” to search and add a capture from Cortex Cloud
Example of a pedal and amp rig, with a cab block capture being used only for auditioning
Using an IR and having it be included in the capture process
This allows access to the full power of Cortex Cloud and provides unlimited creativity in combining all of the content available there, without requiring any rework of the Nano hardware UI/Control system at all. And of course users can then publish their Nano Lab full rig captures to the cloud as well for others to make use of. In this way there’s a natural inflow of many more full rig captures for all following NC users to pick from and get great tones as soon as they unbox the unit.
This would be absolutely amazing. This would really make the possibilities of the NC so much more easy to achieve.
Not to mention, as of right now, there is no way to install captures other than via the cloud. This eliminates the ability to purchase 3rd party capture packs with no way to install them
Voted. Would this also open the possibility of capturing VSTs on the host computer and transferring to the NC?
Si tu peux tu télécharges sur le cloud avec ton pc ou mac et tu ajoutes tes ir ça fonctionne j ai acheté le pack de chez ml soundlab et ça fonctionne
pas d’IR, captures. Je l’ai déjà renvoyé. J’ai acheté Tonex d’occasion et j’attendrai la grande mise à jour en novembre
This is a Google translation from English to French. I hope it is accurate enough to make my point.
“Il s’agit d’une traduction Google de l’anglais vers le français. J’espère qu’elle est suffisamment précise pour faire valoir mon point de vue.”
Later
If this is possible, it would be awesome!
I think the NC should either allow more capture slots or enable users to combine multiple captures into one.
The NC is awesome if you already have a rig, and you just want to capture it and carry it around easily.
But a lot of modern guitar players don’t have a ‘rig’ to capture. For me at least, neural capture is more of a way to try out gears I would never own instead of capturing my own stuff.
I think the NC would be much more appealing to these modern players if they can make up an entire ‘rig’ within the device.
This would be incredible :muscle:t3::fire:
Great idea !!!
+1…
and voted for it, as well …
This would be an excellent “enhancement” - really great idea
New to the Forum, really eyeballing the NC, but the limitations on desktop use ( studio use that is) makes me a bit weary. This nano lab idea is excellent especially in combination with a possibility for desktop control. But browsing around this Forum i see a lot of questions but not so many answers from knowledge people from NSP. Is this normal or do i have to look elsewhere?
For answers from neural you have to write the via Mail, but for everything else, this is the right place. Just make a thread with all your questions and we’re happy to help, as far as we can.
Most of the questions are: when is this feature coming or when will they fix this and this a re things none of us can answer
If this system could be applied to the Plugins, it would be possible to use the amps from the Plugins on the NC.
Just add the send button to the plugins and bypass the wet effects automatically and you’re good to go
