Send Plugin Capture to Nano
As plugin compatibility will likely never come to the Nano cortex, wouldn’t it be great to have a button in the plugins with a send to Nano function.
If you press it, it creates a high quality neural capture and sends it to your cloud, to use it on the nano.
You could dail in the Amps on the PC with the beautiful UI and take it with you, without going through the connection and capturing setup(I know it’s easy enough), but this would feel just like having the plugins in the nano.
If some fx from the plugins would make their way to the Nano, it would be perfect
With the ne V2 Cloud capture tech, this should be fairly simple to implement. Would be great to get the moddeling side to the Nano this way. With plugins and capture tech
