I was trying to use my pedal snake to supply power to my QC. The end from the snake fit into the power supply receptor on the QC but was fairly loose and everytime I bumped it it would power down. I spoke with Jody from pedalsnake and he thought that the QC had a 2.5mm jack as opposed to my line 6 2.1mm jack. If that is the case, the 2.5mm jack should not have fit. So what is the size of it?
thanks rick
I’m pretty sure the QC has a 2.1 mm size.
And I think that is the same size as my line 6 stuff. However, it is perfectly tight in my line 6 HX stomp and loose on my QC. Hmmm…maybe the line 6 is 2.5mm and I have it backwards?
rick
The HX Stomp is 2.5 and the QC is 2.1, I have them both
Thanks you guys! I really appreciate your help on this. It looks like I have had it backwards so all I have to do is order the 2.1mm Powerlines.
rick
