2 Exp Pedals for the Nano Cortex?
Is a way to set 2 Exp Pedals ? Like Wah & Whammy ?
Thanks
Wait, is there a way to set up an expression pedal to be a whammy ? Is there a guide on this somewhere ?
You can control FX1 block with expression pedal. When FX1 is set to pitch, exp pedal controls amount of pitch shift. In the global settings you can limit in which range you want to contol parameters in the said FX block, so you can sort of mimic the whammy effect to some extent.
Yes I have that. 1 Mission (with switch) and 1 Dunlop. the mission is the wah, the switch is no longer used, EXP 1 is assigned to wah and bypass assigned to heel/toe 600ms. If I then touch it it starts wahing. EXP 2 is assigned to the Dunlop as volume pedal. (bypass function not used)
How you Connect 2 exp pedals in the nano ?
