XLR vs TRS output
Both are balanced connections and are basically the same as far as signal flow goes. The main difference comes in to play when using phantom power on a mic input. XLR keeps it’s pins isolated from each other and TRS will short the ring and the sleeve as it’s plugged in. There’s no difference as far as outputs go.
