Wider range of adjustment in individual knobs in IPhone App
I find it a real pain to make small increments in the knobs on the app…
like changing -2 semitones to -3 isn’t smooth and too sensible. Plus the touch always gets confused with the type mode.
It’s good to have a type mode but sometimes you just want to mess around and I find it ends up being a block. Maybe add an extra second of hold press before activating it?
Same goes for delay subdivision. I always have to scroll a bunch before the right Landing on the right option
Yes, it is hard.
Just so you can keep working, you can hold the knobs for 1-2 seconds and a dialog pops up where you can enter exact value.
Thanks, yeah that’s how I’ve been doing it but would be nice for this function to be improved.
Specially in a messing around / jamming scenario where you are looking for a sound and aren’t sure what it is yet
Well, there is lots broken in there.
Check out the compressors and especially Param EQ.
UI is so bad in there that you can not modify it.
Extra params need scrolling down and you can’t.
Also, there is no ms adjustment option for delays.
What if you are not used to BPM at all and did it for ms for all these years.
Every delay I know has a UI that has time adjustment knob with ms adjustment.
Nano App does not. They just give you the option to tap.
