Delay settings are a little bit crippled and cumbersome. A regular delay pedal UI option should be added. As of now, you have to click the metronome and choose sync etc. etc…
It should have BPM and ms options on a slider or a knob. Just like a delay pedal. It is really not practical now. I am talking about Cortex Cloud App BTW. Thanks.
Use an expression pedal to change delay times?
Nano Cortex does not have scenes. I don’t carry expression pedals. Instead I prefer a regular delay pedal knobs that can change delay time. Every delay pedal has this. Most of them has ms adjustments. Modern ones have ms and BPM adjustments as well as tap tempo. Like I said before, it is cumbersome now. It is not a standard delay pedal UI. It is harder to use and bad UI.
Ah, I missed that this is for nano cortex. Sorry!
Actually, I had to edit to make more clear. I was not even talking about the physical NC unit. I was talking about the app to control NC since NC does not have touch screen. The app has Param EQ block and I was talking about the UI of the App’s param EQ.
Ah, that makes sense. It would be a great feature for the app.
