What's new in NanOS 1.1.1?
Yesterday the nano cortex firmware was updated to 1.1.1. I haven’t found any information about it. Does anyone know what’s new? Have any bugs been fixed? Which ones?
I have the same question, I did the update this morning and I cant see any changes …
The firmware notes in the app are:
Fixed:
• An issue where the Level parameter LED ring was illuminated, but the Level parameter itself did not function after using a short press of the Save button to select a save slot in the Neural Capture Save menu.
• An issue where the Footswitch I LED would appear enabled but did not allow toggling between Capture and source after a short press of the Save button to select a save slot in the Neural Capture Save menu.
• An issue where the Headphones Output Level parameter could not be adjusted after using a short press of the Save button to select a save slot in the Neural Capture Save menu.
• An issue where preset switching would occasionally freeze.
• An issue where the Nano Cortex sometimes failed to sync with the mobile app after a Factory Reset was performed.
