Hi guys,
first impressions of owning the nano cortex for 2 days.
Like the build quality, you need to get used to the workflow on the device itself but it’s ok. I’m used to scrolling thru presets instead of captures and IR’s. Hope this will be a feature in a future update. it’s easy to get lost that way.
I tend to turn knobs more then before so that’s refreshing again.
With the software it’s tricky to overwrite presets. Can you find the factory presets somewhere ?
I downloaded some captures from the cloud but after a factory reset they are still marked as being downloaded (green mark) but the list is empty.
Is there a way to “uncheck” these or that they will be downloaded again ?
Regarding future updates, go ahead ![]()
Raf
