Wet Out from QC to the iPad
Hi,
I am trying to record the wet or processed signal from my QC to my iPad. I have the QC connected to the iPad, but I am ONLY getting the dry signal send.
I tried the Voice Memo recorder, and I have tried Cubasis. In Cubasis - the audio source is set to QC, but I am only getting the dry signal.
Arrrrggghhh so frustating - what settings on the QC do I need to send the wet and only the wet signal to the iPad??
Thanks
AJ
try swapping the Dry/Wet USB channels from the Swipe-down I/O menu on the Quad. Click on the USB icon, I think the swap setting is on page 2 of the USB parameters menu. Default is DI= 1/2, change that to 3/4 and you should get the grid feeding thru USB 1 and 2 now.
Thank you sooOOOoo much. That did it.
@VmusicV if this is solved, reply and I will close the thread. Thanks!
YES it did. Sorry about that.
No worries at all!
