Aaaaaah !! Of course you cant change EQ on a capture. It seems to me absolutly normal…
But effects must be change and save . I am sure you will find. Difficult to Help you by the distance…
Keep faith ![]()
OK, thanks for the info. I figured if you could change the level (in post capture mode as you showed last week) you could also add fx, eq, etc. This explains a lot.
So basically… to even out preset levels you adjust the capture, and if you want to add fx, change eq, etc, you do it in the preset.
Call me crazy, but it seems like this should be in the manual. Maybe it is ![]()
Thanks!!
Of course you can add FX ! In a preset. Read thé manuel always berger ![]()
Finally dug into this again, and I was able to boost the level for my solo preset AND add the FX/save. Thanks again, and Happy Holidays!
Happy to read it ! Happy holidays !! ![]()
