Us dlx both models high or low input?
As the title says should i be using the high or low input when using either the reissue or vintage deluxe reverb model on QC? what would be the most “realistic” option? I don’t recall if deluxe reverb amps have a high or low input option.
Thank you!
The normal amp has a high and low input. Input 1 is high, and input 2 is low. So whichever you normally would use with the actual amp
