CorOS Version: 1.4.1
Describe your issue:
So i get this fizzling/volume jump when i either, a) switch scenes or b)stay in the same scene and just press the same scene button…….
i don’t know why its doing that. sometimes if i hold down the button and rotate it, it makes noise too. its almost as if the rotary knob is connected to the output? not too sure.
I also have a ton of crackling and white noise when I even play clean tones.
- Turn on QC
- Play anything
I expected this to happen:
When I play, I expect there to be a lot of noise, volume jumps, and crackling.
- changed cables
- changed guitars
- factory reset
- update to latest OS
- different power supplies
- tried different outputs
- tried different inputs
- tried factory presets
