Tone king Delay Always on.. problem
Can’t figure why there always seems to be delay w tone king plug in.. even w pedals turned off.. I’m in Logic Pro - low latency mode. frustrating.
Confused. Are you talking about the delay pedal sounds in the plug-in? Or are you talking about latency (“delay”) in the plug-in if you’re recording live with it activated?
It’s not from the pedal - as that’s turned off.. most likely some kind of latency from th plugin.. maybe the DAW? maybe the interface?
oddly sounds like a pedal delay though..
Any screenshots you can share of the plug-in and/or the routing/mixing window in Logic would be helpful.
I need to go back to the project.. as I switched logic’s Amp Designer which isn’t too bad..and I’m used to working with it..
