Text Labels on Device Blocks in Grid
I find the purely graphical icons on grid to be frustratingly limited in conveying information.
Yes it’s a reverb but that’s all I know looking at the grid. Is it spring or hall?
Yes it’s a capture, but is it a pedal, an preamp, an amp, an amp + Cab, a pedal + amp + cab?
Particularly problematic when using factory or others presets.
Please allow for at least a small amount of text to overlay the block.
Couldn’t agree more!
Agree, some form of short name to indicate the specific device would be helpful to be able to toggle on/off via settings. Again this requires that people making captures supply a short name of some kind (10-12 characters) that will be useful and there’s always a risk to that, but I almost feel like anything is better than nothing:
Another idea I love but trying to save votes. Might have to burn one though.
Do not save, give all the votes that you have. You can withdraw your vote from any idea of less priority at any time, and give it to a new one if it turns out to be more interesting for you.
That is what exactly what I have been doing.
It’s time to bring the topic back into focus here. It could also look like this… I think the advantages are obvious. Always having to click on the icon to find out what exactly is behind it is a bit annoying.
I really like this idea!
that would be awesome. would be amazing to select that view if you’d like
This would be great. Even if just a 2 to 4 character text string so the user can have an overview of what is what in grid view. Cheers
Excellent feature, and something I suggested for Helix years ago. Interesting that none of the modelers do this that I’m aware of. This would have to be a parameter of the position of the block in the patch, not the block itself as the label should be based on the purpose of the block.
I also asked for years to see this on the Helix. Generic icons that provide identical images for groups of sometimes largely disparate blocks is an inadequate way to convey what is in a signal chain. More descriptive text to accompany icons is an overdue UI feature on modelers.
This is very compelling!
And another related issue is to also be able to customize the colors of certain blocks.
This is especially useful when you have reverb and delay (and especially if you have multiple of them).
See this: Custom colors in stomp block view - #2 by Shimmy
I think this is a no brainer. I cannot tell what my blocks are, like utility ones, etc. This just makes so much sense. VOTED!
I think the framework and style is already in place with how plugin blocks are labeled. Just need 3-4 letters really. You can do this @Neuraldsp-DAO
Really good one! Would be lovely!
Yes, I can imagine, that this is an easy feature to implement.
