Support for Dual Footswitch (TRS) Input on EXP Ports
I’d love to see support for dual footswitches (TRS) on a single EXP port, where each switch (Tip and Ring) can be assigned independently.
The Quad Cortex already receives TRS input for expression pedals – so recognizing two simple switch signals (Tip and Ring) from a passive dual footswitch seems like a natural extension.
Can you map a Footswitch to open the looper on the quad cortex screen or does this only work with midi?
As far as I know, you can’t directly map a footswitch to open the Looper screen — that only works by holding footswitch “C” or using the touchscreen.
Do you mean to say that holding footswitch c of the quad cortex opens the looper screen regardless of what other devices I mapped this footswitch to?
I just tried this and it doesn’t work?
