Stomp mode ,press one button turns the other off
Hey Mates, is there a chance to press one button und turn the other one off ?Eg. Button A turns Booster on, when I press button B the booster should turn off and dist should turn on.
I know it is possible to do with scenes, but I want to learn things about the hybrid mode.
Thanks in advance.
Already possible in stomp mode. Assign both to one footswitch turn one on and one off on the grid. When you hit the footswitch it will turn off the active one and turn on the inactive one. You can do it with more than 2 also. Don’t remember how many but it’s a good many. Anything assigned to the footswitch that’s active will turn off when you press it and anything assigned that’s inactive will turn on. This is a great feature. I use it to switch off dirty amp and overdrive and switch on clean amp in stomp mode. You can also custom label the stomp switch in gig view and name it what you want.
If you can be satisfied by using one switch to alternate between two blocks → Stomp mode
If you want to use two switches because it helps you visualize and process “A is this effect, B is this effect” → Scene mode
Thanks friends , that helped me a lot.
