Stomp mode also activated in Scene mode
So basically my stomp mode switch is activating when I am in scene mode and press the corresponding switch. On footswitch G in scene mode I have my “filth” patch, on that same footswitch in stomp mode it is set to activate an overdrive and an octave pedal in momentary mode. However whenever I am in scene mode and press footswitch G, it will activate the overdrive and octaver permanently. I can turn them off by the normal means, but of course during playing this is not easy at all. The issue is the same even if I only have one device or move the footswitch.
You may need to check Scene Bypass State Behavior in the Settings menu.
