Hi everyone, a question regarding the interaction between stomp and scene mode.
In scene A I have the overdrive at 30% gain, in scene B overdrive is at 60% gain.
If I switch to stomp mode, where I set the overdrive on and off above, what will the overdrive parameters be?
Maybe:if the last active scene was scene A the overdrive will be at 30% while if the last one was scene B the overdrive will be at 60%. Correct?
Thank you
It should correspond to the most recent active scene before you switched to Stomp mode. So if it was 60% when you switch, I think that’s what it would be at
It will be the scene that is on when you last saved your preset. So it’s up to you.
In this case using the QC in hybrid mode would make sense. Bottom 4 switches will be scenes and upper 4 switches will be stomps as you wish.
