Is this possible?
I seems like it should be the default, but for some reason my L & R signals are summed mono in my headphones
Edit: So I put a utility block at the beginning of the signal chains, right when L & R split apart. Each one just turns the volume of that chain down to zero, so I can toggle between left and right manually. HOWEVER, if I go into the I/O menu, and toggle the mute for each channel, the channels clearly are not isolated to L & R
Another weird thing is that I have loop set up in each chain to go into my timeline and big sky. If I mute one of the chains (with the Utility block) I still hear the wet in that ear from the other sides delay/reverb… but if I turn the loopers off, then each channel is completely isolated (again, if I use the utility block)
None of this makes ay sense
Edit 2: I am using USB 3 and USB 4 for my outputs, but if I switch to OUT 3 and OUT 4 the entire tone in my headphones completely changes, but if I switch between those output and listen to my studio monitors, the tones is identical
Edit 3: Also, my headphones start clipping at VERY low volumes. I have everything as loud as it can go before clipping and the volume is just about perfect… but it would be nice to get more headroom. I am using my 64 in ears
Edit 4: There is something completely messed up about the headphone output on this thing. It should not be this difficult
