Stereo amp & cab combo for a punk 2-piece
Hello folks, I’m playing as part of a noisy punk 2-piece at the moment, so I’m looking for what combination of amps and cabs you’d go for in this situation? Looking for inspiration..
I’d ideally like to be able to have a clean setting
And gain, distorted settings that are as full as possible (already thinking at least one Marshall amp for the chonky low-end)
One problem I’ve bumped into already is having a Marshall amp along with a Fender Twin means that on switching scene to higher gain tones mean the Fender’s gain decay is wildly different (i.e. too clean) but don’t want two Marshalls (trying to have some sort of blend)
Would like to hear thoughts (I could waffle on forever about criteria but let’s just jump in)
I would suggest a Diezel VH4 as the single amp but you can have multiple blocks so you get clean, crunch, or high gain, but all into the same cabinet (to taste). Switching cabs for sounds can potentially cause some issues for FOH with EQ adjustments because of how wildly different switching a cabinet can be. In my opinion, it’s best to run 1 cab (or 2 if you want stereo but always both always on)
