I tried to capture the Tech21 DP-3X dUg pedal. No luck. As well a Electro Harmonix Nano POG. Did anyone else have issues with any of these pedals?
if there’s any pitch- or time-based fx involved (or a gate) it will probably fail or at least yield unpredictable results. If you can turn those features off you might get some tonal effect but that’s all you can really expect.
I’m pretty sure I’ve seen dUg captures on the cloud, so it should be doable. Not so sure about the POG, as I assume there’s no way to disable its pitch effect?
Hello. Thanks for your reply. I am fortunate to own a dUg Ultimate Bass 1000. I just captured the two DI outputs. Upper and bottom. Made a preset and added both and it worked great. Once I get it mixed and behaving with some amps and cabs, I will post. Thanks.
