maybe a simple minded question. i have 2 expression pedals and want to add a single button midi switch to toggle between gig mode. seeing as though both expression slots are used do i have to plug the switch to the midi port and if so do i use a trs to midi patch cable
. thanks in advance for the info
Highly doubt that would be all you need, since there’s no way to configure what the midi message is coming from your single button footswitch. You’d need an actual midi footswitch where you can configure what commands are being sent to the QC.
