Scrolling through captures has changed since 3.0.0 update
Just updated to 3.0.0
Scenario:
I have a block in a preset that has an effect/amp from My Captures list and I want to use the top right button on the QC to scroll through other available options.
Before update:
Using this button to scroll through would stay within the available options within My Captures list
After update:
Using this button to scroll now seemingly goes through all the available capture options in alphabetical order. It does not keep you within My Captures list, so most of the options you see will be from the Neural Captures list.
It makes this scrolling functionality unusable if you’re only wanting to choose from options in My Captures list.
Is this a known bug? Is there/will there be a solution?
Confirmed here. Scrolling captures via upper right knob defaults to alphabetical order for all captures, regardless of category or folder structure.
For now, If you click on the device name, it will pop up to the correct folder to select by touch. Not the same, I know, but at least a way to work for the time being.
report that to support@neuraldsp.com if you haven’t already, please.
This issue was encountered and (@xush) reported to neural support via email.
…this needs to be addressed… have the same issue…
