Scene assigned expression pedals
If the changes made by the external pedal / switch are getting carried over when changing the scene should be selectable (globally or per preset), because there are use cases for both.
Also: Push. Neeeural we need this feature!
I’m here for this too. Especially for Pitch shifting. I want to be able to set the min/max range of the expression for each device at scenes.
Scene A: Pitch heel = -5, tow = 0
Scene B: Pitch Heel = 0, tow = +7
This 100% has to happen and needs to happen soon. I want to be able to use an auto-return style expression pedal with auto engage for Wah and Whammy and I want to be able to assign the expression pedal on a per-scene basis. The scene should honor the on/off state of the expression pedal for each effect based on your selection. This will allow users to use one expression pedal and not have to expand into a bigger pedalboard. As it is right now the auto-engage feature totally overrides the scene assignment and engages both effects at once. The workarounds aren’t very functional either.
I also, alternatively, would like to see Whammy assignable to a ‘morph’ switch so you can assign a non latching whammy effect to a Footswitch. The Kemper can do this easily.
Still hoping this gets added soon. :crossed_fingers:
Yes, i’m a kemper convert and I loved that option … with my expression pedal i could blend in my lead sound by putting all of the fx to mix 0% to whatever level I wanted … so every parameter could be set to what you want for the beginning and the end of the “travel” … this second state could be triggered by pushin the same button from the rig you’re in or via the expression ! great idea :slight_smile:
Actually would be amazing if we can assign the same expressions pedal to different effects on different scenes, so for example i have a patch with a wah and a vibrato, i sure don’t want to use them at the same time but would be great if i could switch between scenes and in one scene control the wah and in the other control the vibrato rate for example
