Saving Scene/presets for individual venues
It would be nice to be able to save presets for different gig venues. Lots of the venues i play provide the PA speakers, And as we know, every one of them sound different, And the effects sound different from venue to venue.
Maybe have an option Be able to store multiple presets under that “venue”. And when you return back to that venue, you just go under that menu and search for the venue listing and a list of the amps that you’ve dialed in will appear in the list under that venue, This will eliminate having to mess with your effects and EQ every time you play that venue. The QSC TouchMix Mixers have this feature.
Check by searching but I believe there is an existing request for global EQ that allows saving multiple EQ settings which should accomplish what you need. Until then, you would just need to modify GEQ per venue and keep a record of the various settings.
Couldn’t you just save the preset for each venue in its own folder or setlist? Have those separated out by venue. Could even have the venue name in the preset name.
Just have an EQ block in each preset instead of worrying about the global EQ setting. It achieves the same thing for each output…… you can even get more in depth with the EQ than just the global EQ with the various ones available as a block….
that’s about the only viable option presently- make templates for venues so your work can be saved as a future starting point. Same idea behind Instrument profiles or presets- make a template with the core settings and then build from there
