This is my favorite feature on Petrucci. I no longer need to switch guitars or retune for different songs.
I would get more of the plugins but not till they have the transpose as I change turnings so often. Considering almost all the amp models are based on players that use multiple turnings, you’d think all of them would get as an update. If you won’t retro fit other amps, please make sure to all to all new ones. Wish the SLO had it.
Update: I lied… I purchased Tone King… it is SOOO GOOD! And don’t need transpose for what I’m doing with it for the most part. But if you could add transpose to the SLO-100, I’d pick that up for sure. Thanks for all the great stuff you are putting out!
Adding a reply to concur. The Transpose feature was the deciding factor to choose Petrucci over the others I was looking at, and for the exact reasons you mentioned. Not having to retune is amazing, they should seriously make this a universal feature.
I would also really love to see that function in Nolly, but knowing that there’s a possibility that it could be a problem to implement it, can we at least get an answer is it possible at all? ![]()
Cheers!
If you use the plugins in a DAW, there is nothing wrong with buying the SLO as well.
Put the Petrucci plugin at the top of your signal chain and disable all stomps, amp, cab, gate and effects.
So you only have the transpose effect which you can adjust as you like.
You then integrate the SLO at the second point in the signal chain, which works with the transposed signal.
So I just added the Transpose to the Omega Granophyre.
If you work with the plugin standalone, the whole idea will of course no longer work.
Thanks. I do have a DAW (Ableton) but I usually just run through the standalone. But good to know there is a work around with the DAW. Cheers!
Any news on transpose? Or i’ll have to get Rabea. ![]()
I love using the Transposer feature in Arch: Petrucci (I don’t have any of the others, I just assume all Arch plugins have this feature).
I have found a great use for this tool when I am mixing an audio (vocal, guitar, reference audio) and want to detune it, or increase the pitch universally on that track; Sometimes I’ll put it at the top of the FX Chain. I created a ‘nearly’ blank preset, the acoustic-sounding amp, which doesn’t add any gain, no FX stomps. Then use only the transpose feature on the audio of that track.
So far, at 48kHz 24-bit I am not noticing any artifacts; tuning down works better than tuning up; lots of artifacts in the upper harmonics; needs a lot of EQuing; I like the detune function, can make audio/guitar sound deep; menacing. detune 6-str to A-std (-7) or 7-string to A-std (-2) and it sounds righteous.
I don’t know how much latency this will create (seems quite minimal, when literally bypassing all the other functions in Architect.
How about offering a plugin with JUST the transposer algorithm? Pretty much the only algorithm like it in the industry; I’ve checked a lot of pitch shifters but they are geared towards making harmonies; not exactly what I want… a real-time detuner for the FX chain.
NeuralDSP-Detuner.vst3 ← yeah?
Happy GNU year folks (if you know linux or unix, you’ll get the pun).
Transpose to Toneking would be a very welcome feature.
To play SRV with -1 transpose, I have to switch now to another Neural DSP plugin while it makes no sense it is not available in Toneking.
Many thanks!
