I realize there are already a lot of “we want more MIDI control” requests, but I’m loving the new I/O Settings Presets and wanted to make this specific request: please let us recall a saved I/O Settings Preset with an incoming MIDI command.
I use an external MIDI controller with my Quad Cortex Mini. Being able to select an I/O configuration when I switch guitars live would make the change much easier, without having to open the I/O Settings screen.
As a start I’d be happy to just be able to select from my custom-built I/O presets. For example, if I have 3 I/O presets (SC, HB, Active), be able to send a CC with value 0 to select SC, value 1 to select HB, and value 2 to select Active.
I only brought up input impedance as an example of a parameter that a user may want to change in an I/O settings preset. Impedance is something that could be switched on older units like mine; I’m not sure if newer units (with the codec change) or the Mini allow for this.
Let’s come back to the main topic. The QC should definitely have the ability to change I/O settings presets via MIDI.
