Will the Quad Cortex, Quad Cortex Mini, work as a sound source when recording audio using iphone Camera? Tik Tok Live Streaming? Youtube Live Streaming? Using a USB C capable iphone.
I have been using the IRIG Stream and would love to replace it.
Thanks.
Okay, so I found this in the QuadCortexMini manual but what is the real world result with streaming apps…
“IPHONE® AND IPAD® INTEGRATION
You can use any class-compliant USB audio device with an iPhone® or iPad®. Quad Cortex mini can be used with such devices via USB-C (iPhone 15 or later).
iPhone 14 and older generations will need the Apple® Lightning to USB-C Camera Adapter to recognize Quad Cortex mini as an external microphone device.
This feature allows you to use Quad Cortex mini with audio apps such as GarageBand® for recording purposes.”
I use my iPhone with the QC and the Camera App sometimes and it works great. You just have to Switch the dry and wet, so that the wet signal is on channel 1&2
