This is a very well known issue. It’s hard to believe that you were not aware of it. A “grounded” power supply, even if there is such a thing, will not ground the Quad Cortex.
It is designed to be grounded via XLR to a grounded power amplifier, and that is the only way it can be grounded.
I don’t mean to be argumentative but, I doubt that anyone is able to feel 12 volts DC at such limited amperage capability. If so, never touch your car door! Is there a possibility that somthing the QC is connected to is leaking current?
The QC is not grounded on purpose. You have to hook it up to something to ground it. It is this way to prevent ground loops during performances. Pluggin into your pc via the USB, plugging the XLR’s into a grounded device or plugging into an amp (can be off) via the jacks will ground the device.
I’ve been thinking of making a cable with a 6.3mm plug on one end and a wall plug with ground on the other. Simply connect the grounds together and leave the rest untouched. Havent tried it yet though.
Anyway, using a grounded supply isnt gonna fix your issue because the qc itself just doesnt have a path to ground via the 12v input.
Also fyi, center negative barrel adapters are the standard in guitar industry. No idea why though.
You can in a lot of cases feel the build up voltage (it’s common-mode interference to be exact) if the devices case is made of metal and not grounded to mains ground. Almost all MacBooks have this ‘problem’ if used with an ungrounded power supply. It’s not that they shock you but you can feel a weird ‘resistance’ when moving your fingers across the metal surface. (Newer MacBook Air MagSafe Power Supplies deliver around 14v at 3 amp max for comparison)
Nope. At least not the newer ones. Some time ago (before the introduction of the m-chips I guess) apple shipped the power supply with two adapters: One with a meter or two of additional cable and one without (wall-wart style). The long version is/was grounded (three prong plug) but the short version isn’t (two prong). Today at least the smaller supplies are only shipped with the wall-wart style insert.
I’ve only seen negative center positive on the outside. One time out of many pedals an older Digitech pedal had the opposite adapter. Negative inside is the norm.
