QCX Plug in mode
Can we not use the stomp mode on X plug ins after they have been put into my QC?
The plugin stomps are on the QC and work in stomp mode
well there must be something I’m doing wrong. I have to control the X plug ins on the cortex control. am I missing something? my QC buttons don’t work, they don’t even light up on the actual pedal…
There must be. The plugin devices that are compatible with QC load as normal blocks and function the same way.
I think we’re missing something…
what exactly are you trying to do? Which plugin is it?
Im have for instance Gojira X, when I fill the block chain with the amp and effects they are not controlled by the pedal. I have to use the cortex control on my computer to turn the overdrive or delay I want on or off. unlike the factory delays and overdrives. What am I missing?
are you in Stomp Mode on the QC?
You are just building a preset from scratch by adding blocks from the Plugin section?
Perhaps in the Menu settings under Device options you have the auto-assignment of switches bypassed?
Stomp Mode Bypass Assignment: A global setting for whether
footswitches are automatically assigned to blocks’ bypass
settings. If you enable AUTO-ASSIGN, blocks will be assigned to
footswitches in the order they are added to The Grid
pg. 15, Manual
Are you clicking on the block in the grid??
I think they’re not clicking on the block to have the parameters come up for the blocks…… the bypass or stomp mode wouldn’t affect them adjusting the block settings
