QC w/ Supro Delta King 12 Amp. Will Power Amp Input work?
Hi everyone! Apologies for a simple question. I’m a bedroom player w/ a Quad Cortex, mostly play with my headphones.
I was planning on buying an FRFR for when I don’t wear headphones, I don’t need it to be loud as I don’t play live.
With that said, I have a Supro Delta King 12 Amp with a Power Amp Input in the back. I was wondering if that would work if I connect a line from QC Output 3 to that? And would i need to adjust anything?
Again, apologies for a basic question i just can’t find much information and I’m really not good with the technical stuff!
Thank you!
You might need to adjust the master volume of the QC if you go into the power amp of your amp. Not sure how yours may function, but it’s common for the master volume of a tube amp to not work if you plug into the power amp/effects return. It’s common for them to act as if the master volume is all the way up. So just start with your QC master volume low in case that it how your amp functions.
