PowerBank Thread for Quad Cortex (No More AC Cables)
You need the mission engineering 529 to convert to 12v
I have tried several powerbanks, too. The most important is USB-C output value + USB-C cable thickness (power handling). Not every USB-C cable is able to handle 12 volts with higher amount of ampers. May powerbank with capacity of 40.000 mAh and ability up to 20V with 3A is able to power my QC together with Mipro wireless for over 6 hours… :metal::+1::wink:
From my powerbank I go from the usb c port to the 529 via a standard usb c to usb c cable and from the 529 via the 12v centre negative 2.1 x 5.5mm Plug.
Never had a problem
Hi, question for all, that are using the 529m method. I’ve figured out, that my 529 drains the powerbank (about 2,5% per hour). So without unplugging it after playing the powerbank is empty after one or two days. Has someone of you made the same experiences?
For all of those tired of chasing cordless freedom with the QC (like me), I decided to stick with a power cord. This guy offers a substitute for the pitiful AC adapter included with the QC. When mounted on a pedal board, they appear quite sturdy - mine is due in the mail in a week or so. He only has 8 or so left. Check them out: Quad Cortex Power Supply Replacement IEC Neural DSP - Etsy
Besides that was not that what I asked for ;-). I would never ever buy a power supply without the official needed certificates like CE in EU. If your apartment burns down, no insurance company will pay :-). And why should I, there are thousands of viable alternatives to the official QC power adapter from well-known manufacturers. What is the advantage of something like that hand-built (as long as you do not personally know the person who builds it and its reputation).
I was making a general comment or suggestion because I have heard several people requesting a better adapter. I wasn’t suggesting ANYTHING for you. Thousands of viable alternatives for adapters?? You couldn’t name 100 good ones. Why not try to be a positive addition to the discussion instead of a condescending one?
Sorry, since I asked a fairly specific question I thought your post was meant as a direct answer to my question. And yes, a thousand was exaggerated. Exaggeration makes vivid, as we all know ;-). So everything is fine :slight_smile:
Btw. Solved my problem with a new powerbank. I went for a Shargeek Strom 2 with DC outlet. Works realy nice and has power for about 5 hours. So no more 529m or other converter cables for the QC any more. Now I yout have to clean up the cable management under the board a bit :slight_smile:
@in5y372 Did you still have to use the polarity reverse cable using the Shargeek powerbank?
Yes, I do still use a polarity reverse cable.
I have a question regarding the 529m. I’m using it with a powerbank and everything works fine, but when I connect it with a normal usb Plug (45W) the outputs of the qc are very very low. This is not the case with the powerbank nor the normal power brick. Does anyone have an idea, why this happens?
Sounds strange. Can you tell, what usb-plug you are using? I can imagine, that it maybe don’t have the power delivery version that the 529m needs. But this is just a guess. Is you 529m is set to 2A oder 3A? (It’s a little switch inside teh 529m)
It’s a BEOPDOHR 63 w Adapter
Output usb c 12v 3a
With this one the QC starts but quits half way
An anker one
https://www.amazon.de/dp/B0BQLGTCG3?psc=1&ref=ppx_yo2ov_dt_b_product_details
with this one everything starts fine, but the output is extremely low.
With my power pack everything works well.
I just wanted to use one Powebrick for loading my accupack and running my qc at home, but at the moment I don’t know what to do
thanks for your reply @in5y372 . I ended up getting one as well :slight_smile:
A bit pricey but user experience feels very premium.
Was planning to run it as a “UPS”. 12V out of the DC jack with the polarity flip adapter, going into the QC. And PD 12V going into USBC1 input. But the two ports are so close together.
So I’m thinking the alternative, 12V into the DC jack (from original QC PSU with polarity flip adapter). And PD 12V (with a 12V triggering adapter that is USBC on 1 end and a 2.1mm barrel at the other) going into of the power bank and into the QC.
Hey! Here is my benchmark station aha:
For those who are wondering if it’s really worth a try: the Blackstar PB-1 battery life powering the QC (minimum screen and switch brightness) + the GLX6 is approx. 1h15.
I am planning to buy the 529P POWER BANK and I know that the qc is center negative and the 529P POWER BANK is center positive. How do I know which cable to use to connect the two, and which side goes into the qc and which side goes to the 529P POWER BANK?
Hello in5y372, how are you? Your pedadboard has been very good, I have also bought the shergeek storm powerbank and it works wonderfully but I have a couple of doubts with it, how do you charge the power bank? I have tried to do it with a phone charger and it takes too long. Could it be charged with the original power adapter of the quad cortex? Has it happened to you that when you put the Power bank in dc mode when you turn off the quad cortex the storm restarts and there is no way to turn it off? Thank you so much.
I use a 65W USB-C power adapter for charging. A simple phone power adapter has too little power. I have not tried DC charging yet.
You can also use the 67W power supply from Shargeek. It also looks funny. Retro 67
I usually have the DC port turned off, otherwise the QC will drain the powerbank over time even when turned off. When I want to play, I then turn on the DC port on the Storm 2. The QC then starts on its own. After playing, I first turn off the QC and then I deactivate the DC port again. I have not yet experienced that the Storm does not respond.
Has anyone got experience with powerbanks like this one?
https://www.amazon.co.uk/Yangers-uninterrupted-supply-24000mAh-battery-Black/dp/B09T76VFK6/
It appears to be basically a DC pass through with a battery in the middle - so if the power source feeding it fails it switches to battery. It looks like as usual a reverse polarity cable would be needed to use with the QC.
Most of the time my QC is sat in one place so a wired power supply isn’t a problem - I’m just thinking ahead to gigs where there’s more risk of people unthinkingly turning off the power strip etc.
