Quick one - FX loop needs a phase switch, please!
I can’t use ‘Mix’ to blend the dry signal around my Bogner Harlow in the loop without it killing my signal. Can be fixed with a splitter but it’s a waste of a row, and if I then bypass the FX loop; phase is wrong again and it goes silent.
1 block solution
Utility-> gain → phase switch
I find my self using this frequently with parallel inputs. Wet (h90) / dry
You can’t use that ‘inside’ the FX loop block, though, to make use of the dry blend within that block.
That would help with my splitter setup, but it’s still far from ideal wasting a 2nd row to get a dry signal around a compressor first thing in my chain…
