Parameters sensitive to dynamics and/or pitch
Is it possible to make parameters sensitive to dynamics and pitch? , for example, an octaver that activates only from a certain note or a delay where the repetitions increase if we play harder. It would be amazing, like what the new pedals from Gamechanger do, and I don’t think there’s any modeler currently capable of doing that. Thanks!
Fractal has a thing called Pitch Follower which does some sort of adjustment depending on the pitch of the note.
Also the think Line 6 has some effects that respond to dynamics. Maybe Dynamic Delay or reverb
The request below has been around in the forum for a while, but hasn’t gained as much attention as I would have wanted. It’s a “kitchen sink” approach to adding a ton of new functionality in the form of LFOs and envelope followers that could simply be assigned to any parameter of any block on the grid. Give it a look:
It doesn’t mention pitch, though.
