Parallax - Cubase Elements 8 - No sound
Hi,
Parallax standalone works, but when in Cubase, the sound for the given track disappear when adding the plugin. Even when I remove parallax from the track, the sound is still gone. It is clearly sound there (the frequency band and faser is showing sound, but it does not come out.) All the other tracks are unaffected…
Using parallax version 1.0.0 (x) from 2024.
I’m using Cubase Elements 8.
Neural DSP - Archetype works without issue.
are you monitoring your track?
Thank you for the quick reply.
Had the same settings as I have on Archtype petrucci , where there is no problem with the sound.
I upgraded from Cubase elements 8 to artist 14. Then the Parallax worked. No need for further support.
Have a good day!
Best regards
Anders
Sendt fra Outlook for Android
Thanks for the update! Glad you got it solved!
