Out of resources after update
i just updated and now some of my scenes get “Out of resources - Please remove last module added.”
i removed several effects, but still get the message. CPU is at 6%
Any ideas?
have you tried rebooting several times in a row, or a system recovery or reset?
Many times the HUGE updates will see some ‘glitches’ at install that can be sorted after a few restarts. I’ve had to do it sometimes when something wasn’t working quite right after an update.
I’ve haven’t seen this ‘out of resources’ error, but I’ll do some snooping around
its seems to be the mono cab block on any of my plugins (Gojira,Nolly).
The stereo ones work fine, but the mono cabs are draining all my resources.
Everything worked fine prior to updating today.
Report it to Support@neuraldsp.com if you haven’t. sounds like a bug; someone on Discord is having a similar issue with plugin cabs
+1 same thing happened to my presets post update
im in contact with support, ill let you know what we come up with.
They already patched this with an update
