This makes no sense to me why is the nano can’t really be used in mono ? Not sure if this been talked about here before , but is there some sort of a trick that be used for mono ? I tried putting a mono as the last in the chain that does not work .
Your question is confusing. I use the Nano frequently with my FRFR (mono) with no issues.
Maybe give some more details.
Using an frfr in a bedroom or in live band context? Ok , try using a dual delay in a chain in a mono setup and tell me how that sounds
Live band mostly. Most FOH engineers want mono anyway but yeah, it sounds great.
Man if you have two different tempo like ( 375 & 500 ) on the dual delay in the chain of the nano cortex and you are going to FOH , you will only hear ONE tempo barely and hear the other . It’s ok dude even neural dsp is aware of that issue . No need to try being a super fan .
I ended up buying an XLR stereo to mono converter cable. So yeah, it’s not available on the big unit either.
