Hello All, I have played polynesian/Hawaiian music for over 20 years. I played through a sans amp GT2, Boss DD3 and Rv5 to emulate a twin reverb type sound. I’m finally venturing out and trying to explore other genres, mainly reggae and R&B. Im not sure the best way to get started. Ive used chat gpt to help setup some patches, but i dont know what order and why it matters, how to adjust effects or what the desired result of each effect is. I’ve googled but its sort of like drinking from a fire hose and im feeling a bit overwhelmed. any push in the right direction would be greatly appreciated.
Hey Welcome, no reason to sweat it…ya could start by just reproducing what you’ve been using but using the QC effects…and most important… just play!. One thing you can find helpful is downloading other players free patches that have a sound you like then see what effects they used and see the order they put them in…and PLAY. Have a blast…Trust your ears and can AI
One of the best ways to learn the QC is to use/study the factory presets. Explore the FX blocks within the presets to see what they do and how they react when you modify them. The QC has the easiest UI IMO and honestly, 95% of using it can be done without even cracking the manual open. Of course, reading the manual will help with some of the settings and use cases.
Thanks for the great recommendations. I have gone through and created a patch to match my “poly” pedal board ive used over the years, while its not exact its fairly close. also created a patch for steel guitrar, acoustic, and bass. or tried to at least. My thoughts were having a single pedal board i could use for all instruments instead of having to reconfigure my board depending on what instrument i was playing. bass wasnt too bad since i only use a Sans amp bass driver, for acoustics i was using a Boss AD-5 and recently purchased an empress para eq but have yet to use it live. ill dive into the presets and play around and probably be back with even more questions lol
welcome to the QC- I think you’ll love it for what you’re describing. It’s great for multiple instruments. Lately I’m enjoying using it as a submixer and swapping several instruments on it.
As far as the order of fx blocks, you can set it up as a pedalboard emulation, where most effects would be placed BEFORE the amp/cab and then you’ll get some extra flavor on those fx, or you can approach it like a studio setup and put stereo or ‘wet’ fx AFTER the amp/cab. Of course, the great thing about the QC is you can put anything anywhere and if you like it it’s cool.
Don’t forget, if you make a preset you genuinely love, you can upload it to Cortex Cloud for others to use and check out too. Use the tags to add something like “Hawaiian” or “Polynesian” to make it searchable for that style, and who knows, you could be nailing a tone that others are looking for. If you’ve got 20+ years of knowledge of a style of music I know nothing about, I know I for one would love to hear what you come up with. Welcome aboard!
So my 2 cents, would be to leverage Googles Gemini AI, Ive had a lot of success lately with audio engineering questions, things that if I had to search on my own would take hours, so you might try asking some setup questions like I’m using this before and now I’m using the Quad Cortex/mini and want to port over my setting (or whatever), Gemini’s been fairly accurate in direction for how to set up things, it may save you time from halving to learn the QC from ground up, One things for sure getting on the QC platform will be very rewarding for you imo.
Always use the forum too for questions too peeps like to help..
Cheers
