As of right now I’m enjoying the nano. My only current gripe is… I would like to be able to use the high and low cut from the IR section. I feel as though that would be very helpful.
Agreed on this.
My thoughts here are that the option to have the bank switch select banks of presets would make the nc really much nore useable live.
For me selecting banks of captures makes little sense on the front of the pedal. This can all be easily handled through the app.
For live, having 4 presets in a bank available. Then another 4 in another bank via the bank button would up the anti massively.
Future firmware option for live operation maybe?
I would also happily swap the pitch feature for a compressor.
I agree as well
Wah, Whammy & Tremolo ![]()
Agree re both. The transpose on the nano (and the quad) are pretty poor anyway so there’s not a lot lost
i think the transpose is at least on par with the drop, which i also have on my board. looking forward to replace it with my nano
It is pretty much until you play fairly complex chords with a clean sound. There’s a noticeable difference there. For distorted rock sounds though it’s fine.
I think the opposite. I find it awesome in the Nano. Do you use it with the volume up enough to not hear the strings?
I would like a tremolo to alternate with the chorus and that the delay can go below 200 ms
I also find the transpose on the nano excellent
Very usable and inspiring use it all the time for a different take on a composition
Agreed. It also only adds like 1ms of latency while the drop is like 10+ on its own.
Adding wah, whammy and trmolo would be really great!
And it should come with MIDI implementation, so that we can use an expression pedal THROUGH a MIDI controller so that we don’t have to choose either or when using the only port available.
How nice it would be!
Does anyone know if there is any kind of midi imprelementation chart for the nc? So that rather than only Sending program changes, we could switch on and off blocks in the selected patch?
I coukd defo live with using the nc to select 4 different rigs with a small midi controller added to add/subtract compression, overdrive, delay, reverb mod etc. This would be such a useabke fly rig if we could add these functions within a single patch. Shouldnt be difficukt to achieve either.
I was told by Neural we currently only have the midi PC implementation. A number of us have asked extended midi control, especially with the fx blocks. Let’s hope it’s on their development horizon.
Nano feature request
DAW REC
I want to be able to monitor directly when recording with the nano Cortex microphone input.
